Клеко
graysparrow
летать...
Цанговые зажимы
Во весёлый - 15 работаю с металлообработкой, но то, что обычный цанговый патрон незывается "Клеко" узнаю впервые - с такой лаконичностью можно долго искать нужное...
Русско-язычные поисковики отзываются на "цанговые зажимы" в том числе и о КЛЕКО... Если конечно речь идет о поиске а  не о  правильности указания предмета.
На постсоветском пространстве таких вещей нет, поэтому не надо мудрить, наберите "Clecos"  и будет Вам счастье.
Хотя, при желании, для общего развития, можно поискать у нас...
E
erissky
Цанговые зажимы
А мы их просто фиксаторами называли!?
455
http://www.kevincaron.com/MUSeINGS-1007.html
WHAT'S THAT?
So often, people see something in Kevin's studio and say - well, you know. "What's That?" focuses on a subject that is dear to many peoples' hearts: tools....
Keeping it Together
When you are trying to convince metal to swoop and swerve, twirl and twist, clamps can be your best friend.
A cleco
But sometimes a regular clamp just isn't enough.
That's where the cute little critters called clecos ("KLEE-kos") come in. Kevin learned about them when he was in the Navy, but this handy form of fasteners, which are also called "blind holders," are also used by custom car builders to hold sheet metal parts in place before final welding.
When Kevin began working on Möbius, he knew they'd be handy to help convince the metal to conform to the piece's unusual shape.
To use clecos, you drill a 1/8" hole into the piece on which you are working, then insert the cleco with compression pliers (another special tool, of course!).
Möbius, with clecos attaching it to the frame
When you release the pliers, the cleco springs shut, exerting as much as 20 pounds of clamping pressure. After use, you simply pop open the fastener with the pliers and weld shut the hole. Voila!
Click here for more information about clecos or to buy your own.
If you'd like to know more about a specific tool, let us know - we might have an answer. Email us at info@kevincaron.com
ТО Цесны то Клеко, а правильно произносится КЛИКО если вы тут попросити клеко, вас просто непоймут....[highlight]вот так акценты появляються что в Русском что тут. [/highlight]
А с каких пор слово Клико русское.мож ты педа....;Dрусс....кий владеющий английским в совершенстве,  поучиш меня правельно произносить слова на моём языке :-/
_Alex_
Я люблю этот Форум!
Кишинев
КликО -  слово русское с 1812 года  ;D Надо, Миша, лучше историю родной Франции изучать  :IMHO
А в молдавии вино домашнее вкусное [smiley=thumbsup.gif]
Уверяю Модавское вино нивкоем случае не лучше Калифорнийского...... Напа и Санома Валли слышал про такие места? ;) И я ни одного дня не пропускаю без хорошего стакана красного вина...но только во время ужина
Конечно одно затруднение (но легко преодолимое) они не дешовы ;D
http://www.beauwinetours.com/
А насчёт Клико как хотите так и называёте...не хотите учить немного английского грен свами... как оно есть ....я рад за вас!
А доступное калифорнийское, пить совершенно невозможно, в отличии от значительно более дешевых молдавских. Но это лирика.
В сухом остатке: КЛеКОСЫ - КЛеКО. Это прижилось. клЕко - цанговый зажим отныне русское слово  ;D :IMHO
