Страниц: 1 ... 55 56 [57] 58 59
Летательный аппарат Kasperwing (Прочитано 515387 раз)
henryk
Krakow
Re: Летательный аппарат Kasperwing
Ответ #1680 - 03.12.17 :: 22:45:26
Pavel_RB писал(а) 26.11.17 :: 22:21:41:
видео.
https://www.youtube.com/watch?v=WNrUgww8ZvI
-nie KASPERWINGi !
henryk
Krakow
Ответ #1681 - 19.12.17 :: 13:14:30
http://www.homebuiltairplanes.com/forums/attachment.php?attachmentid=68151&d=151...
-за зиму превратим в ВВИП ! (100 кВт).
Pavel_RB
Новичок на форуме
г.Гродно, Беларусь
Ответ #1682 - 20.12.17 :: 23:17:14
henryk писал(а) 19.12.17 :: 13:14:30:
Скромно переспрошу ВВИП это высоковольтный источник питания? На фото скорее потребитель чем источник Улыбка .
henryk
Krakow
Ответ #1683 - 20.12.17 :: 23:36:14
Pavel_RB писал(а) 20.12.17 :: 23:17:14:
ВВИП это
=Вертикальный Взлёт И Посадка...(экономлю чернила!)
-сдвоенные моторы 202/80 (50 кВт) + 2 контроллера
500 А,120 В.
henryk
Krakow
Ответ #1684 - 24.12.17 :: 16:05:11
henryk писал(а) 20.12.17 :: 23:36:14:
http://www.homebuiltairplanes.com/forums/attachment.php?attachmentid=68263&d=151...
-хватит ли мощности?
henryk
Krakow
Ответ #1685 - 25.12.17 :: 01:21:10
"I have owned, built and flown a Kasperwing UL.
I have done the "vertical mush" many times.
The wingtips are very effective as are the rudders. The response of this wing in all ways is slow and predictable. Not what you'd expect from a tailess aircraft. It can be flown at 18mph in full control w/o tip stalling and as I recall there is no washout. Most vertical mushing is done w some fwd speed probably 7 or so mph. Vertical sink rate I think was about 500fpm while flying normally at 18mph was about 200fpm.
Personally I think the airfoil and extended airfoil at the wingtip holds the best posibility for sailboat design. The airfoil is very stable and would be easy to control as a wing for the boat. But it's a single surface wing and would only function with the wind coming from one side of the boat. The airfoil does not work with a negative angle of attack. So I don't see any way to use Kaspers UL aircraft wing for a sail on a boat.
Easy Rider, May 5, 2016 "
maket
Сдавшихся - в разы больше, чем проигравших.
Ответ #1686 - 28.12.17 :: 20:57:36
http://www.homebuiltairplanes.com/forums/attachment.php?attachmentid=68151&d=151... зиму превратим в ВВИП ! (100 кВт).
Henryk, а ты не мог бы ссылку дать на обсуждение этой темы?! а то по ссылке открывается attachment, а что это за хрень с трубой на фото и для чего оно - ветку уже  найти не получается.
henryk
Krakow
Ответ #1687 - 28.12.17 :: 21:02:14
maket писал(а) 28.12.17 :: 20:57:36:
-это я поместил снимок спаренных моторов 202.80,
с двумья контроллерами =китайские...
(на сайте ХБА это легче,не нужно ужимать...)
http://www.homebuiltairplanes.com/forums/showthread.php?t=28760
maket
Ответ #1688 - 30.12.17 :: 00:36:22
а при каких оборотах у них 100 кВт ?!
henryk
Krakow
Ответ #1689 - 30.12.17 :: 11:29:42
maket писал(а) 30.12.17 :: 00:36:22:
KV=25...
Vmax=120 V   I max=500 A (<2500 RPM)
-в действительности двойной мотор (12 kg) выдаёт мощность меньше
чем в два раза 50kW...пока не мерили.
-хотим иметь запас мощности для эксперимента !
KAA
Ненавижу Солидворкс!
Россия, Казань
Ответ #1690 - 30.12.17 :: 12:17:06
henryk писал(а) 25.12.17 :: 01:21:10:
Ну и зачем такой режим нужен? При посадке этой схематичной конструкции с вертикальной скоростью 2, 5 м/с,- колёса в стороны! Печаль
henryk писал(а) 30.12.17 :: 11:29:42:
-в действительности двойной мотор выдаёт мощность меньше
Действительно, всякий электромотор выдаёт меньше, чем потребляет, и эту разницу обусловливает его КПД.
Вы мощность на валу как замеряете? Подмигивание
В описанном случае, потребляемая мощность =60 кВт.
Мощность на валу будет меньше.
WWW
henryk
Krakow
Ответ #1691 - 30.12.17 :: 12:26:45
KAA писал(а) 30.12.17 :: 12:17:06:
Вы мощность на валу как замеряете? Wink
http://emrax.com/products/emrax-twin/
=это данные по максимумам...на самом деле китайские продукты
похуже,надо их брать с запасом.
=мощность (механическаая) это обороты умноженне на момент
на валу (мерится тормозом).
-едем к Богдану,у Него проф.измеритель момента=
http://www.kasperwing.com/Kasperwing%20images/tobby4.jpg
PS="Ну и зачем такой режим нужен? При посадке этой схематичной конструкции с вертикальной скоростью 2, 5 м/с,- колёса в стороны!"
=для радости!
(лучше приземиться с такой скоростью
чем кувырнуться при посадке на картофель или кукурузу...?)
=+ возможность посадки "в колодец"
ЗЫ2=если крыло (парашютирующие) прицепить к тележке
на телескопической консоли,то скорость приземления
можно сильно уменьшить...
henryk
Krakow
Ответ #1692 - 04.03.18 :: 13:50:52
=120 В, 2*500 А ! (два блока управления моторами)...
ЗЫ=какие будут мнения по поводу применения для К-В
оппозитного мотора 170 кубов?
https://www.rcgroups.com/forums/showthread.php?2680197-DLE-170-Twin-Gas-Engine
+два соосных винта?
https://www.youtube.com/watch?v=aaVBwcvjwGg
henryk
Krakow
Ответ #1693 - 13.03.18 :: 13:13:42
http://a.moirier.free.fr/A%E9rodynamique/Dispositifs%20a%E9rodynamiques/What%20h...
=istorija...
https://arxiv.org/pdf/1703.07720.pdf
=teorija.
https://books.google.pl/books?id=49C17H53YmcC&pg=PA110&lpg=PA110&dq=kasperwing,k
asper&source=bl&ots=yBhoMMAW4o&sig=GAB3rkaImzqOF_UQjJiGGghJrM8&hl=pl&sa=X&ved=0a
hUKEwjy1KvEn-nZAhVIYZoKHXj1BSsQ6AEIdjAM#v=onepage&q=kasperwing%2Ckasper&f=false
=kniga.
henryk
Krakow
Ответ #1694 - 13.03.18 :: 21:11:54
henryk
Krakow
Ответ #1695 - 15.03.18 :: 22:17:33
https://www.youtube.com/watch?v=hpgpgvvMDuo
=EASYRIDER...coaxial.
https://www.youtube.com/watch?v=Xe1g1JrRRkY
-12:45 =исследование зависимости тяги от расстояния винтов!
« Крайняя редакция: 16.03.18 :: 00:01:39 от henryk »
henryk
Krakow
Ответ #1696 - 16.03.18 :: 10:42:36
henryk писал(а) 15.03.18 :: 22:17:33:
-может Кто англоязычный сможет расслышать про
"оптимальное расстояние" между винтами?
5ZF
США, Северная Каролина
Ответ #1697 - 16.03.18 :: 13:59:46
Они про конкретную величину не сказали.
Сказали только, что это имеет большое значение и показали, как они его определяли с помощью этого эксперимента. Система контроля показывает полученную тягу и как она изменяется при приближении второго пропеллера, вращающегося в противоположном направлении.
Своя Любашка ближе к телу!
henryk
Krakow
Ответ #1698 - 16.03.18 :: 16:38:10
5ZF писал(а) 16.03.18 :: 13:59:46:
Система контроля
-я там не обнаружил измерителя тяги...?
=на большом самолёте пропеллера не далеко друг от друга.
henryk
Krakow
Ответ #1699 - 16.03.18 :: 18:28:26
Сказали
-у Вас нет контакта с этой Группой?
(ELECTRO FLIGHT)
https://www.electro-flight.com/contact-us
https://www.electro-flight.com/contra-rotating
https://www.youtube.com/watch?v=j67z0BxWGm0
=звуковая интерференция,
=за пропеллером немалые препятствия(блок управления,
крепление)
5ZF
Ответ #1700 - 16.03.18 :: 23:35:57
henryk писал(а) 16.03.18 :: 16:38:10:
Система контроля
Она электронная, встроена в систему управления левым двигателем, он так сказал.
henryk писал(а) 16.03.18 :: 18:28:26:
Нет, меня такие вещи не интересуют.
Такая схема расположения пропеллеров давно известна и использовалась в прошлом веке на стратегических бомбардировщиках и на пассажирском Ту-114, так что тут ничего нового нет, просто они пытаются ее применить в варианте с электротягой.
henryk
Krakow
Ответ #1701 - 16.03.18 :: 23:55:31
5ZF писал(а) 16.03.18 :: 23:35:57:
-конечно,на электромоторах сделать соосный привод легче,
чем на ДВС...
спасибо за инфу!
5ZF
Ответ #1702 - 17.03.18 :: 02:48:46
Да не за что.  Улыбка
henryk
Krakow
Ответ #1703 - 06.04.18 :: 22:58:47
Lapshin
Строитель ВС
Ответ #1704 - 07.04.18 :: 12:51:01
9-й год ветке пошел - только, кроме деклараций мы ничего так и не увидели. Кто скажет, когда, наконец, можно будет убедиться в Сумакс больше пятерки и в запредельных качествах? Боюсь не дожить.
henryk
Krakow
Ответ #1705 - 07.04.18 :: 17:21:56
Lapshin писал(а) 07.04.18 :: 12:51:01:
9-й год ветке пошел
-Владимир Павлович,Вы всегда правы!
года текут быстрее ручейка...я сам перевалил за 70,
да и показывать есть всё меньше.
-на зимовку перебазировали зелепушный КАСПЭРВИНГ поближе
к Кракову (200 км до Мельца,а сейчас 30 км в сторону Закопанэ).
-опробовуем спассистему с ракеткой на сжатый газ (без неё
боязно парашютироать,хотя и ожидаемая скорость ок.5м/с).
-заодно начали сбросы парашютов с 20-метровой вышки,
с целью притармаживать обьект перед приземлением для СВЕРХмягкой посадки !
-в прошлый сезон Войтек выполнил пару полётов на скорости
ок.5 м/с  (18-20 км/ч)...
=поверял на машине протёчный спидометер (прозрачная трубка с поплавком) с крыльчатым анемометром=совпадение вполне приемлимо!
-завтра надеюсь получить композитный винт (заместо деревянного)=шумит меньше,толкает силнее...
-сильно обещающие результаты получаем для противофазных
винтов,больше 10 кГс/кВт...
=как-то так.
здравия,Хенрик!
https://lotnie.pl/media/kunena/attachments/3626/12483626_1289898507702235_595010
https://lotnie.pl/media/kunena/attachments/3626/11214172_1192036524155101_621497
http://www.samolotypolskie.pl/uploads/Products/product_867/Henryk_Doruch_01.jpg
>30 liet!
аэробайка
Экс-Участник
Ответ #1706 - 07.04.18 :: 18:44:44
во всей теме по каспервингу впечатляет только одно---407 тысяч просмотров за девять лет Ужас а вот реальной движухи в массы любителей сла чудо крыла так чего то и не наблюдается Озадачен такой постоянный пиар ---а где стаи этих пепелатцев Не лечупора задуматься ---почему народ не верит Язык
Lapshin
Строитель ВС
Ответ #1707 - 07.04.18 :: 19:51:16
Это религия, сэ-эр: и только для посвященных.
henryk
Krakow
Ответ #1708 - 07.04.18 :: 20:35:49
Lapshin писал(а) 07.04.18 :: 19:51:16:
https://lotnie.pl/media/kunena/attachments/3626/20160725_133222-1.jpg
=малый примерчик= летом мы втиснули пенопластовые заполнители переднего кармана="коэфф.летучести"
вырос процентов на 20 !(скороподьёмность,АК...) ?
https://lotnie.pl/media/kunena/attachments/3626/trailingedge.png
ЗЫ=всё что летит в конце-концов упадёт!
-поэтому я придумал и испытываю на себе "квантовый бампер"
=перегрузки свыше сто "ЖЭ",путь торможения =миллиметры !!!
http://www.homebuiltairplanes.com/forums/showthread.php?t=28760&page=4&p=425406#...
=#57
henryk
Krakow
Ответ #1709 - 07.04.18 :: 21:21:50
Цитата:
пора задуматься ---почему народ не верит Tongue
-а не лучше смастерить своими руками,для 100% уверенности ?
