eXmajor-ME
Любитель Малой Авиации
- Middle East ㉿ Central Asia
...от 97 л.с. до 140 л.с.
...от 140 л.с. до 200 л.с.
[edit]ULPower is proud to announce that the range of engines on offer is extended with 4 new types 6-cylinder engines, ranging from 140 hp to 200 hp.
The installed weight of the UL520i and UL520iS is 108 kg [242 lb] and like the popular UL260 and UL350 line of engines the new engines are direct drive, horizontally opposed, air cooled, electronic ignition, multi-port fuel injection and FADEC (Full Authority Digital Engine Control). The FADEC system controls the fuel/air ratio and ignition from start-up to shutdown so the engine is always operating at optimal performance thereby increasing power and economy while minimizing wear and tear and reducing pilot workload.[/edit]
75,5 КБ Просмотры: 325
127,4 КБ Просмотры: 339
