Страниц: 1 ... 12 13 [14]
Аэропракт-32. (Прочитано 129615 раз)
А.Веггер
Бостон, шт. Массачусеттс
Re: Аэропракт-32.
Ответ #390 - 28.09.18 :: 21:11:23
Кстати если говорить об Австралии вот как CASA поясняет что это за зверь за такой
Цитата:
What is a Light Sport Aircraft?
LSA is a new category of aircraft that does not replace any existing category. It is not intended for existing aircraft already operating under a different airworthiness category. It is a small, simple to operate aircraft. It can be a ready-to-fly production aircraft or it can be a kit built aircraft of the same make and model as the production aircraft.
With regard to the requirements of the regulations, a light sport aircraft is an aircraft, other than a helicopter, that has:
A maximum takeoff weight of 600 kg or 650 kg for an aircraft intended and configured for operation on water or 560 kg for a lighter-than-air aircraft.
A maximum stall speed in the landing configuration (Vso) of 45 knots CAS.
Two person, including the pilot.
A fixed landing gear. A glider may have retractable landing gear. (For an aircraft intended for operation on water, a fixed or repositionable landing gear)
A single, non-turbine engine fitted with a propeller.
A non-pressurised cabin.
If the aircraft is a glider a maximum never exceed speed (Vne) of 135 knots CAS
The types of aircraft that may satisfy these criteria are 3-axis aeroplanes, powered parachutes, weight-shift control aeroplanes (trikes), gliders, balloons, airships and gyroplanes.
Administration – an LSA may operate under either a sport and recreational aviation organisation such as RA-Aus, or under CASA.
What is not an LSA
The types of aircraft that do not fit in this category are:
Hang gliders
Paragliders
Multi-engine aircraft
Helicopters
Complex aeroplanes with retractable undercarriages or turbine engines
sportster.aero - это Ваш путь в небо.
WWW | Skype/VoIP | YIM
5ZF
США, Северная Каролина
Re: Аэропракт-32.
Ответ #391 - 28.09.18 :: 22:23:17
Ага, практически все, как в США, а вот если бы вы прочитали чуть-чуть дальше, то обнаружили бы там вот это:
8.2.1 Production LSA issued with a Special Certificate of Airworthiness can be used for the following purposes:
(1) private operations;
(2) flight training; and
(3) glider towing, and are subject to those operating limitations specified in CAR 262APA.
Т.е. и в Австралии те же самые ограничения, что и в США и даже по буксировке планеров есть ограничения и указано где их смотреть. Не удивлюсь, если и в других странах будет то же самое.
Слово СПОРТ в них и означает, что эта категория создана для удовольствия.
Не забываем еще, что для коммерчесой деятельности нужна еще и коммерческая летная лицензия.
Про возможные изменения в правилах для категории LSA в США я в курсе и очень жду их. Но пока это только в проекте.
И с дронами я тоже в курсе, у меня и коммерческая лицензия на них есть.
Своя Любашка ближе к телу!
А.Веггер
Re: Аэропракт-32.
Ответ #392 - 28.09.18 :: 23:44:13
Дело в том что для зарабатывания денег на самолетике то ли Advanced Ultralight то ли S-LSA надо еще иметь и право этим делом заниматься. например даже имея самолет S-LSA я не смогу давать уроки Инструктажа если у меня нет Лицензии Пилота Инструктора. Кстати инструктаж студентам для сдачи на лицензию Спортивного Пилота (Sport Pilot License)  можно давать и на легких самолетах не LSA типа Piper 140 или Cessna 150 А эти самолеты сертифицированы по типу. это совсем не запрещено. Но вот например сдавать экзамен на вождение (Test Ride)  студенту после прохождения инструктажа на Cessna 150 все равно придется на S-LSA Aeroprakt - 32 : есть и такая фишка если уж глубоко копать в дела. То же и с Баннерами. Даже если у меня есть специальный S-LSA (где он там разрешается на баннеротаскании) и нет лицензии на таскание баннеров - мне не заплатят ни копеечки за мою работу если я таскаю эти самые баннеры. Вот общие положения за что могут платить в Европе (Франция к примеру)
Цитата:
an aircraft that is flying or operating for the purpose of, or in the course of:
(i) the personal transportation of the owner of the aircraft;
(ii) aerial spotting where no remuneration is received by the pilot or the owner of the aircraft or by any person or organisation on whose behalf the spotting is conducted;
(iii) agricultural operations on land owned and occupied by the owner of the aircraft;
(iv) aerial photography where no remuneration is received by the pilot or the owner of the aircraft or by any person or organisation on whose behalf the photography is conducted;
(v) the carriage of persons or the carriage of goods without a charge for the carriage being made other than the carriage, for the purposes of trade, of goods being the property of the pilot, the owner or the hirer of the aircraft;
(va) the carriage of persons in accordance with subregulation (7A);
(vi) the carriage of goods otherwise than for the purposes of trade;
(vii) conversion training for the purpose of endorsement of an additional type or category of aircraft in a pilot licence; or
(viii) any other activity of a kind substantially similar to any of those specified in subparagraphs (i) to (vi) (inclusive);
shall be taken to be employed in private operations.
Merces
Новичок на форуме
Re: Аэропракт-32.
Ответ #393 - 05.11.18 :: 12:50:24
Всем доброго времени суток! Подскажите пожалуйста, в Москве кто-нибудь катает на аэропракте-32?
Yakovlyev
Я умею строить самолеты!
Киев, Украина
Re: Аэропракт-32.
Ответ #394 - 05.11.18 :: 13:10:36
Первый А32 уже доставлен в Россию и находится в московском регионе. Наш дилер Владимир Шомин сейчас заканчивает сборку этого самолета. Обратитесь к нему по этому вопросу.
Merces
Новичок на форуме
Re: Аэропракт-32.
Ответ #395 - 06.11.18 :: 09:26:53
Спасибо! Попробую отыскать его.
Yakovlyev
Киев, Украина
Re: Аэропракт-32.
Ответ #396 - 06.11.18 :: 09:57:34
На нашем веб-сайте есть его контактные данные.
Amir tmr
24 воздушная армия
Re: Аэропракт-32.
Ответ #397 - 06.11.18 :: 12:35:23
Merces писал(а) 05.11.18 :: 12:50:24:
В Орловке собирается
ПП UUTO
Amir tmr
24 воздушная армия
Re: Аэропракт-32.
Ответ #398 - 06.11.18 :: 12:38:20
ПП UUTO
Merces
Новичок на форуме
Re: Аэропракт-32.
Ответ #399 - 06.11.18 :: 20:15:17
Оо Улыбка Улыбка Я так понимаю обращатся за "полетать" нет смысла...хозяин судя по фото на нем еще сам не летал)) Подскажите, это единственный экземпляр А-32 в России?
Yakovlyev
Киев, Украина
Re: Аэропракт-32.
Ответ #400 - 06.11.18 :: 20:50:47
Пока, да.
Amir tmr
24 воздушная армия
Re: Аэропракт-32.
Ответ #401 - 10.11.18 :: 08:18:46
Почти готоффф
ПП UUTO
Merces
Новичок на форуме
Re: Аэропракт-32.
Ответ #402 - 16.11.18 :: 15:10:21
Класс!Улыбка Улыбка
DIR
Private Pilot R44
🇷🇺 Vladimir-city
Re: Аэропракт-32.
Ответ #403 - 19.11.18 :: 08:35:47
А что это за фенька в а32  прикреплена к педалям?
✈ UUIP Pavlovskoe Airport, Владимирская область... WELCOME
Yakovlyev
Киев, Украина
Re: Аэропракт-32.
Ответ #404 - 19.11.18 :: 10:09:17
Резиновые жгуты загружатели.
Андрей Полетаев
Самолёт хорошо, а планер лучше!
Казань
Re: Аэропракт-32.
Ответ #405 - 09.01.19 :: 16:36:50
Заранее извиняюсь (может уже объясняли), но хотел бы узнать, предусмотрена ли установка разрезного руля высоты и буксировочного замка для буксировки ультралёгких планеров (АС-4-115 например). Возможно ли это на серийном А-32 как доп. опция или надо оговаривать перед постройкой конкретного борта мероприятия по усилению хвостовой балки?
  Есть небольшой опыт буксировки планера Янтарь-стандарт без водобалласта за А-22, а так же пробовал  поднимать аэропоезд  Бланик (2 человека) за А-22 (тоже 2-е в кабине) просто как эксперимент, получилось. Думаю 115-ти килограммовый планер легко бы смог, не было рядом в то время его.
  Пока просто интересуюсь.
Не мешайте самолёту лететь - это же САМО ЛЁТ!
Yakovlyev
Киев, Украина
Re: Аэропракт-32.
Ответ #406 - 09.01.19 :: 17:41:59
Для А-32 такой опции пока не предлагаем, а А-22 сертифицирован и испытан в Германии для буксировки планеров весом до 750 кг.
Андрей Полетаев
Казань
Re: Аэропракт-32.
Ответ #407 - 09.01.19 :: 17:48:53
Спасибо!
