Hummingbird 260L Helicopter.
Leon CX
Вот интересный четырехместный кит - 138тисяч и +,+,+…
http://www.vertical-aviation.com
http://www.vertical-aviation.com/gallery2/main.php?g2_itemId=295
Leon CX
Уже с 2008 года в России ;D
И как ? Поделитесь впечетлениями ? Купили китом или уже собраній ?
АН
Главный Джабировод страны
Дождались.  ;) Вертолёт в подмосковье. Фотки выложу поже.
eXmajor-ME
Любитель Малой Авиации
...с верхним обтекалем и воздухозаборниками!
HUMMINGBIRD 260L Helicopter
...выглядит посолиднее!
...стоимость КИТа:
[edit]PRICING INFORMATION
The Following Items are included:
All Documentation
Instruction manual, drawings, photographs, illustrated parts manuals, maintenance and flight manuals.
Lower Cabin/Airframe
Preformed bulkheads/ribs, pilot drilled skins, castings, and hardware.
Upper Cabin/Airframe
Preformed ribs/firewall assembled with skins and hardware. Hardpoints and skins preassembled and riveted in place.
Landing Gear
Main and nose wheel/brake assemblies, oleo struts front and rear, 4130 chrome-molly steel weld assemblies, all castings and hardware.
Nose and Windshield
Windshield and composite nose chin windows, preformed ribs/bulkheads, instrument panel section, composite doors, and hardware.
Tail Cone
Tail cone, 4130 chrome-molly steel tail cone support, castings, stabilizers, and hardware.
Tail Rotor
Tail gearbox, Intermediate gearbox, pylon casting and tube, tail blades preassembled to hub painted and balanced, driveshaft, spline couplings, tail skid, control rods, and hardware.
Main Rotor
Main rotor head, 4130 chrome-molly steel pylon, main shaft, castings, bearings, swash plate components, preassembled main gearbox, tail driveshaft with bearings, support brackets, spline couplings and hardware.
Flight Control
Dual cyclic, dual collective, and dual pedal controls, mixing unit, tail cables, vibration dampers, brake cylinders and lines, control rods, rotorbrake, electric trim, and hardware.
Fuel System
57 gallon aircraft bladder tank, gaskets, filler neck, covers, fuel quantity probe, sump assembly, fuel strainer, and hardware.
Electrical
Switches, circuit breakers, wire harness, connectors, relays, navigation lights, quadrant, cables, and hardware.
Seat
Composite seats and hardware.
Cowling
Composite engine cowling, upper section, ribs, brackets and hardware.
Main Rotor Blades
Blades preassembled.
TOTAL: $138,600.00
The following items are not included: engine, instruments, paint, upholstery, battery, crating and freight.[/edit]
[edit]OPTIONS:
Engine Lycoming VO-435-A1F
Includes 4130 chrome-molly steel engine mount, elastomeric lord mounts, engine cooling fan, cylinder baffles, cylinder jacket, oil cooler and composite adapter, oil tank and mount, exhaust and silencers, driveshaft, flywheel, clutch and freewheel unit, carburetor heat adapter, air filter, electric fuel pump, carburetor, fuel & oil hoses and fittings, alternator, starter, vibrator, ignition harness, spark plugs and hardware.
$51,920.00
Engine LS7
Includes 4130 chrome-molly steel engine mount, elastomeric lord mounts, electrical harness, starter, alternator, dual computers, flywheel, exhaust silencer, radiator and fan, oil tank and mount, driveshaft, clutch and freewheel unit, flywheel, air filter, fuel & oil hoses and fittings, electric fuel pumps and hardware.
$38,300.00
Fuel Injection System
$4,285.00
QuickBuild Fuselage
Assembled airframe including, windshield, nose, center instrument console, doors, tail cone and landing gear.
$48,300.00
Section 1 thru 5
Includes the fuselage upper and lower cabin sections, landing gear front and rear, nose and windshield, instrument panel, doors, tail cone support, tail cone and stabilizers, all fittings, castings, hardware, manuals and drawings.
$63,870.00
Right Rear Cabin Door Kit
$1,062.00
Quickstart Kit — Gets you started before your kit arrives
Includes manuals, drawings, sheetmetal for lower cabin section.
$2,895.00
Pre-bent Angle Kit — Factory supplied pre-bent angles
$2,540.00
Landing/Search Light
$920.00
Instrument Kit
Includes the following gauges; dual tachometer, airspeed, altimeter, manifold pressure, transmission oil pressure, fuel pressure, cylinder head temperature, engine oil pressure, engine oil temperature, fuel quantity, volt/ampmeter.
$6,335.00
100 Hour Inspection Kit
$38.00
Blades Painted With Safety Colors
$1,800.00
Sheet Metal Tool Kit
$985.00
Crating Charges
4 Special Wood Crates
$1,850.00
(Specification and Pricing Subject To Change Without Notice.)[/edit]
АН
...здесь продают! 250 000 $!
Объявление на RSTcars.com: продам АВИАТЕХНИКА Вертолет Hummingbird 260Lelegance
Тут полная туфта. Звонили туда спрашивали. Чуваки пообещали  привезти и собрать за 3 месяца. Даже сделали аудио запись телефонного разговора ;D ::) :cool:
